Last activity: 10 May 2018 1:18 EDT
What does query string contain in PEGA LOGIN URL
Hi ,
I am using SSO can you explain what are the query string values in URL after PRServlet.
https://xxxxxxxxxxxxxx/prweb/PRServlet/cTIwP01Sm6wbO-co1YnspWwpmujJAfZPx-cq4PHUbpc%5B*/!STANDARD?pzPostData=-1620677814
PEG
Here's the answer I got from one of my colleagues:
When we POST data to PRPC we have to handle the case when a redirect occurs - for example when posting data to just the /prweb/PRServlet will cause a 303 redirect so the processing runs within the proper context - accessgroup hash
so we need to store the posted data because a 303 redirect response will then trigger a GET request from the browser
so the pzPostData is a pointer to a hashmap containing the posted data so it can be referenced/used when redirects occur.
All users see same query string in URL.
https://xxxxx/prweb/PRServlet/6LNtIs_6n5e-yVZe94ExObX5llv7EEzp*/!STANDARD?pzPostData=-832304156
Can you clarify what is this and why its same
Hi Team,
Can you pls reply
PEG
The immediate hash (e.g., cTIwP01Sm6wbO-co1YnspWwpmujJAfZPx-cq4PHUbpc%5B*/ above) is a hash code that is generated from the Access Group and the user's ruleset profile. Are you referring to this, or the pzPostData?
https://xxxxx/prweb/PRServlet/6LNtIs_6n5e-yVZe94ExObX5llv7EEzp*/!STANDARD?pzPostData=-832304156 I am referring to the on ein bold letters. It is same for all users, what is it and why
PEG
PEG
And I see my colleague created this post in answer to your question: https://collaborate.pega.com/discussion/undertstanding-pzpostdata
