What is difference between Optimized and Legacy code in in Repeating Layout Modes?
Thanks for posting your query to PSC:)
Optimized code - Recommended option. Select optimized code to use flexbox-based layout in your form which helps you in achieving responsiveness.
Legacy code - Select legacy code to use float-based layout in your form. This type of layout uses the inline block when setting several layouts side-by-side inline.
Please check the below link for clear understanding:
- Chinmai Sravanthi.
Thank you Sravanthi.
