Virtusa
Last activity: 11 Jul 2019 7:14 EDT
Validation messages are not display for read-only fields in Pega 7.3.0
Recently we have upgraded our application from 7.2.2 to 7.3.0.
I can see Validation messages for read-only fields in 7.2.2 but not 7.3.0.
It would be great helpful if you have any ideas on it.
***Updated by moderator: Lochan to update platform capability***
Upon reviewing the associated Support Request, SA-62975 Validation messages do not display in read-only mode fields was generated as the resolution.
Please refer to this SA if you have the same issue.
TechMahindra
In Presentation Tab of the cell properties, there will be a check box "Show validation messages in read-only mode"
Try checking the checkbox
Trustmark Insurance Company
Hi Venkatalakshmi,
I tried this.. But the validation message is not being shown under that property. It is still being shown as page level error for Read Only property. It was the same behaviour even before i selected the checkbox.
Please help.
Rajendra Prasad
Merkle
Could you please check the control rule used for showing the data? Also, check if your application had customize that control in previous version, and might be overridden during upgrade.
Gopesh
Tata Consultancy Services
Could you please provide the snapshots of your configuration ?
Pegasystems
Can you please check, if the Field Level Errors have been enabled in the Harness rule.
Hoong Fai Yee
Tekclan Software Solutions
CollabPartnerz
Pleas share the screenshots of your configuration
Venkatesh K
