Virtusa
The uploaded file template could not be recognized. Please upload a valid file.
I need to parse a Excel which will as a attachemet in the WO. Im using MSOParseExcel for this functionality.
I have placed the file in the service export directory with my logic. Created a binary file template and passed the file path and the template name as parameters for the MSOParseExcel.
While executing it, getting the below error
The uploaded file template could not be recognized. Please upload a valid file. Refer to template MyExcelTemplate for details.
the excel file which im using as attachemnt follows the excel emplate.
Even tried with the file which is uploaded as the binary template and getting the same error.
Could someone help me in resolving this issue.
(PEGA version 7.2.2)
Aruldevan
***Updated by Moderator: Marissa to add SR Details***
Hi Aruldevan,
How are you providing value to the template field in MSOParseExcel parameter.
Can you share snapshot of the parameter setting when calling MSOParseExcel activity.
Virtusa
Hi
Attached the tempalte excel sheet and the runtime execution sheet.
Hi Aruldevan,
I couldn't see the configuration screens in the attachment. Could you please share your configuration of calling MSOParseExcel activity .
Regards
Saran Kolla
Virtusa
Please find the attached configuation.
Please let me know if any other info required.
Aruldevan
Is this issue resolved, could you please let me know what is the solution, i am facing the same error.
- The uploaded file template could not be recognized. Please upload a valid file. Refer to template PropertyDamage for details.
Virtusa
Team,
Any solution for this problem.
Aruldevan
Please check the logs when you see this error.
Are you seeing any variant of these?
- Column Header validation failed...
- Unreadable template: no entries...
- Error in parsing Excel file...
Virtusa
Checked in the Rules log and there is no errors.
Aruldevan
That's very interesting. Because if you see that message, the code I reviewed should be generating some errors in the log to correspond with it.
INSTELLARS GLOBAL CONSULTING PRIVATE LIMITED
I'm seeing error "Column Header validation failed..." when passing ValidateSheet name param. Even though i'm downloading same template and uploading i'm getting same error. Please help on this
This might require a more in depth research by GCS team.
However, before I recommend you to reach out to GCS team via SR, I would suggest you to run the same use case for any of the OOTB template that is available and see whether that works or no.
This will help us to isolate whether the issue is with the template or process.
Hi Aruldevan,
Do let us know the SR number if you create an SR with Pega Support for this. We will tag it to this post and track it until resolution.
Thanks!
SR-B46764
Thank you. I have updated the post accordingly.
The issue was with the File name parameter. Instead of using the complete system path, we used as file://web:/StaticContent/global/ServiceExport/MSOData.xlsx and the issue got resolved.
Tata Consultancy services
HU
Hi Marissa,
We are using the filepath mentioned above ' file://web:/StaticContent/global/ServiceExport/DVBProducts1.xlsx'. But still we are getting the same error '**** The uploaded file template could not be recognized.'
Could you please help with this?
Thank you.
Infosys Australia
Hi Team,
I am facing the similar issue. I am using Pega 7.31. Please help if anyone got the solution
Thanks!
Infosys Australia
Thank you Lochana. I will create a separate post for this
Virtusa
Could you please validate the FS file name paramener as per the solution given.
Aruldevan
Infosys Australia
Hi Aruldevan,
I have tried that also. It is not working.
Subhajit
