DXC
SA
Last activity: 29 Jan 2020 15:23 EST
Upload a file to specific node using Connect file
I am using a File-Connect method in an activity and uploading the created file to a directory location. Here I need to specify the node since all file should go to that specific node.
Is there any way to achieve this?
Don't know if another approach if feasible but If you can have a NFS mounted on all your nodes, you'll upload from all server always "locally" to same location and your specific node could then read all files from this NFS.
Regards
Anthony
