Princeton Blue
Last activity: 3 Oct 2016 5:24 EDT
Update session attributes while switching application
we are currently working in Pega 7.1.8 environment.
we have an entitlement system,which maintains user attributes like Access Group,Workbaskets,Skills,Roles and Work Group for a user.All these attributes are assigned to a session at the time of login.
But there is a possibility that the user can have a multiple unique combinations of [Access Group,Workbaskets,Skills,Roles and Work Group].If the user has more than 1 Access Group,we provide the user an option to switch access group.
While the user switches the access group,we want the other attributes like workbaskets,skills,roles and work group assigned during the login to get wiped off and set to new values.Its mostly like re-running the authentication activity again.
I want to know if there is a possibility of updating the session attributes after the session is established while switching the application ? Whats the process of doing it ?
I see there are 2 activities available (ApplicationSetUp and ApplicationProfileSetUp) for making changes.Can I make the changes in these activities ? whats the impact ?
Hello Sunil,
I think you might have done little R&D on tracing the code while switching the app from designer studio. As we all know, the ApplicationSetup is being called and the other inner activities are used to set some of the initial stuff like portals, properties, threads etc. From these collection of activities, we have call to Code-Security.ApplicationProfileSetup and is basically allowed to extend or do the customization from the customer side changes. Even in our apps also, we did change this activity instead of main activity: ApplicationSetup. But, ours is a different story compared to your requirement. Based on my understanding with your requirement, I think the same activity: ApplicationProfileSetup can be changed with all your logic. As we are using our apps since so long time, we didn't see any issues after making the changes as I mentioned above and I think we took the suggestions from Pega on this earlier too. To me, you can think in that direction but let's wait & see how Pega experts recommend in this context.
Ravi Kumar Pisupati.
