Blue Cross Blue Shield of MA
Last activity: 19 May 2021 10:43 EDT
Unable to select Case to create from Data Flow
I'm using PEGA Personal Edition 8.5.1
I created a Data Set. Tested. Works. Has Data.
I created Data Flow and sourced it from the Data Set.
I want to create Cases from Data Flow. So I change "Abstract" to "Case" and saw a drop down to select my Case show up. However when I open the drop down, no Case is visible.
Data Flow and my Case Type are in the same ruleset.
What am I doing wrong? I have tried this many times - Refresh, Create Case Type before creating Data Flow / Data Set, restarting server, everything.
