Kafka Data Flow Error
Pega Version : 8.7.2
Server : Websphere
DB : Oracle
Established Kerberos connection successfully. Running the dataset manually works fine and able to see the messages.
However , when running the Real Time Data Flow, it gets stuck in 'Initializing' with below error:
Failed To Prepare Partitions: org.apache.kafka.common.errors.TimeoutException: Topic <<TopicName>> not present in metadata after 30000 ms.
Also, when we tried to manually run the data set from activity, it fails stating Exception executing the dataset. Please note, we are able to see the jsonData for the events in tracer though.
Server : Websphere
DB : Oracle
Error trace when running data set manually from activity:
2023-06-28 04:25:29,160 [ WebContainer : 36] [ STANDARD] [ ] [ ] (set.kafka.KafkaBrowseOperation) ERROR - Error deserializing stream while reading from Kafka topic com.pega.dsm.dnode.api.dataset.kafka.KafkaDataSet$KafkaDataSetBuilder$$Lambda$4850/0x00000000a4bb44f0@30640d06
at com.pega.dsm.kafka.api.serde.JsonSerde.deserialize(JsonSerde.java:59) ~[d-node.jar:?]
at com.pega.dsm.kafka.impl.serde.ConfiguredPegaSerde.deserialize(ConfiguredPegaSerde.java:59) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.deserializeMessage(KafkaBrowseOperation.java:347) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.convertRecordToClipboardPage(KafkaBrowseOperation.java:302) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:210) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:167) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:157) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecordsAndComplete(KafkaBrowseOperation.java:149) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.lambda$browse$0(KafkaBrowseOperation.java:145) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.reportError(KafkaBrowseOperation.java:261) ~[d-node.jar:?]
at com.pega.dsm.dnode.impl.dataset.kafka.KafkaBrowseOperation.processRecords(KafkaBrowseOperation.java:217) ~[d-node.jar:?]
Any help would be appreciated.
