Capgemini Technology Service India Limited
Last activity: 12 Oct 2025 14:14 EDT
Data Flow with Kafka Source, Activity and Data Transform Not Executing at Destination
I’m facing an issue with a Data Flow where the source is a Kafka Data Set. The data flow runs through three components: Source, Filter, and Destination (Activity).
Each component shows success when I run the data flow. However, the issue is that the Activity configured in the Destination is not actually getting executed.
Here’s the detailed setup and observations:
The source Kafka data set is working fine and filtering is also happening correctly.
The Destination is configured to call an Activity.
In the first step of the activity, I have added a logger (to verify if the activity runs), but nothing appears in the logs.
I also tried calling a Data Transform instead of the activity and added logging there too — but again, no logs were generated.
It seems like the execution part (Activity / Data Transform) is not being triggered, even though the data flow execution shows success across all components.
There are no errors in the data flow run details or in the logs.
I also ensured that:
The class of all rules (data flow, data set, activity, and data transform) is the same (Work- class). The ruleset is the same for all rules.
I also plan to enable the logger specifically for the data flow to capture more details, but as of now, there’s no visible error or log entry related to this issue.
Has anyone faced a similar situation where the data flow runs fine but the activity or data transform at the destination doesn’t execute?
Any pointers or suggestions would be appreciated....
Further update:
Errors observed after enabling data flow logger:
1. InvalidParameterException: Invalid value of requester parameter
2. PRRuntimeException: Failed to get the ruleset list of the requester
3. Executing remote operation fetchRuleset failed for requester
4. Failed to get the thread name of requester
5. StreamServiceException: Stream SPI error
6. StreamServiceException: translate Kafka exception
7. InvalidReplicationFactorException: Replication factor 3 larger than available brokers
8. Failed to start service VBD/default
9. RTDG-based BDMS service provider internal start operation -
Lambda start client error
