suneratech
Last activity: 24 Sep 2019 15:46 EDT
Data flow not created
Data flows (Batch Process) are created in our dev environment either from agent activity or direct activity execution. Whereas in our QA environment data flows are not created through both the approaches (Agent/activity).
There are no differences in system configuration and DSS in both the environment. We are not able to trace the Dataset.
DataFlow rule on the explicit run, the Batch process is created with auto-generated work object id.
From Activity DataFlow-Execute method is executed successfully but the batch process is not created in the decisioning landing page. (which is working in Dev environment and able to see the batch process DF id in decisoning landing page).
Have you got a running DF process in QA? What version of Pega are you on. For example, here is a screenshot from 7.3.1. What does it show to the right if you click on status "Normal"?
suneratech
Hello Paul,
Thanks for your response. We are using Pega 7.3.1 version.
In decisioning services landing page, all the node status are normal.
Are you able to run the DF manually in QA? If not, any errors?
suneratech
Hello Kevin,
From the Decisioning landing page, on click of "New" DF (Batch process) is created successfully.
suneratech
After enabling logger: com.pega.dsm.dnode.impl.dataFlow
I have seen the below errors:
2019-05-16 05:17:04,511 [tp-nio-5451-exec-193] [ STANDARD] [ ] [ XXX:01.01] ( internal.mgmt.Executable) ERROR xxxx-xxx|10.119.20.xxx - Only authenticated client may start this activity: RULE-OBJ-ACTIVITY PEGA-DM-DDF-WORK ADDWORK #20170501T125928.649 GMT ReqID=BHT6I54U4B5H9PN56B0M3LLRNS4KYG36I com.pega.pegarules.pub.PRRuntimeException: Error: You lack access required to execute RULE-OBJ-ACTIVITY PEGA-DM-DDF-WORK ADDWORK #20170501T125928.649 GMT. at com.pega.pegarules.session.internal.mgmt.Executable.updateStepStatusAndLog(Executable.java:912) ~[prprivate.jar:?] at com.pega.pegarules.session.internal.mgmt.Executable.activityProlog(Executable.java:844) ~[prprivate.jar:?] at com.pegarules.generated.activity.ra_action_addwork_db4db4af2ddc4865d9e3d30003879de0.perform(ra_action_addwork_db4db4af2ddc4865d9e3d30003879de0.java:53) ~[?:?] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3597) ~[prprivate.jar:?] at com.pega.dsm.dnode.impl.dataflow.activity.PRPCActivities$PRPCActivity.execute(PRPCActivities.java:100) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.activity.PRPCActivities$PRPCActivity.access$400(PRPCActivities.java:69) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.activity.PRPCActivities.addWork(PRPCActivities.java:20) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.service.persistence.db.RunDbPersistence$WorkObjectCreator.create(RunDbPersistence.java:400) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.service.persistence.db.RunDbPersistence.getOrCreate(RunDbPersistence.java:82) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.api.dataflow.service.DataFlowRunFactory.from(DataFlowRunFactory.java:51) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.service.DataFlowServiceImpl$6.run(DataFlowServiceImpl.java:272) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.dataflow.service.DataFlowServiceImpl$6.run(DataFlowServiceImpl.java:269) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:52) ~[dnode-7.3.1.jar:?] at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper$2.run(ServiceHelper.java:202) ~[dnode-7.3.1.jar:?] at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1327) ~[prprivate.jar:?]
We've seen a very similar issue like this with a client who wasn't using PaidMedia but had found this exception was related to a data flow for that functionality.
In that scenario, the logs provided more details directly before the above exception was seen.
Problem in executing BatchData-Decision-DDF-Run-Partition: code: 1400 SQLState: 23000 Message: ORA-01400: cannot insert NULL into ("PRPC_DATA"."PR_DATA_DECISION_DF_PART"."PXWORKID")
Please check for an occurrence like this. The root cause of prior issue was "Update Match Rate activity runs in agent context every one hour, the Update Match Rate activity triggers the data flow run by using the pxRunDDFWithProgressPage API to create audience snapshot. User might have not enabled the Pega Paid Media capabilities; hence the exceptions are being noticed."
The solution provided was:
"Perform the following local-change: "UpdateMatchRate" activity is required if User have enabled paid media capabilities. User can safely disable "UpdatePaidMediaMatchRate" agent since the paid media capabilities are not enabled".
suneratech
Thanks of the response @PaulGentile_GCS
I have created SR (SR-D16324) regarding the above issue, Pega support team is looking to find the RCA on it.
Naveen
systemhaus r.tetzlaff
DE
Hello, we had a similar behavior here. Is there an answer to the SR already?
DE
Hi @RonnyT46,
This SR is not resolved yet. This is with our Engineers.
Upon reviewing the associated Support Request, the following local-change is the resolution:
Keep the different accessgroup for batch requestor and for Operator.
The access group as PRPC:Agents for batch requestor would be fine.
Or
Uncheck the authentication box for ADDWork activity as in later releases it is unchecked..
or
Pass the pyOpertor in runoptions page.
