Unable to install hotfix's
Unable to install the hotfix even after followed the instructions mentioned in Verifying hotfix authenticity by using a Pega Keystore
1) Getting the following error when importing hotfix file.
2) Downloaded the certificate from digicert.com
3) Using the utility, create a Java KeyStore (JKS) with the DigiCert root certificate:
keytool -import -trustcacerts -keystore pegahotfixkeystore.jks -file DigiCertTrustedRootG4.crt -alias pegahotfix
4) Created keystore file and uploaded the generated JKS file .
5) Created DSS
5) Created DSS
Application server was restarted but still issue is not resolved .
***Edited by Moderator Marije to add Case ID tags***
