TD
Last activity: 23 Jun 2021 0:19 EDT
unable to change Pega log directory
In order to customized pega's logging directory i updated
export JAVA_OPTS="$JAVA_OPTS -Dpega.logdir = <My customized path>
as well as updated the same in standalone.conf. But pega still creating log files in its default directory. It is not picking up the path i provided in pega.logdir.
In prlog4j2.xml each log file configured as example below.
<RollingRandomAccessFile name="PEGA" fileName="${sys:pega.logdir}/PegaRULES.log"
Previously i tried by replacing ${sys:pega.logdir} with <My customized path> in prlog4j2.xml but that didnt work either.
Can you please point what am i missing here?
@Abhishekg0292
I finally able to resolve this issue. i was extracting Prweb.war and repacakging it on my windows machine by using jar commands. For some reason the WEB INF folder was missing after repacakaging. so instead of extraction i only replaced prlog4j2.xml by using command jar -uvf and redeployed it. all the log files are now being created in customized target folder.
