UI for advancing the case in the Exercise system is failing to appear
So a colleague and I are working our way through the System Architect Training on PEGA Academy so that we can understand how to use PEGA. However, suddenly while we working through the exercises the included Exercise System it would no longer display the "No, Advance the Case" option to continue testing stages of case types. We the tried to change stage (because it may have been that this was normal) but it gave us the "local actions are only available when you are performing the assignment" which more or less meant we were stuck. I've been rummaging around in lots of parts of the settings, but I'm worried that if I fiddle with the configuration too much I might break my case exercise. Is there a fix for this issue?
Also just to clarify, my coworker and I are on seperate exercises but are experiencing the same issue. Im on Exercise 19 and he is on Exercise 31.
***Edited by Moderator Marissa to move from Pega Support Community to Pega Academy***
