SmartRules
Last activity: 4 Oct 2016 7:49 EDT
Two Column Sidebar Main - Sidebar Width keeps saving as 3000
In the Skin pyEndUser71, there is an OOTB Column Layout called "Two Column (Sidebar - Main)". There you can set the Sidebar width for the Left sidebar. Default setting is 300. I didn't change it, I changed something else in the skin (padding on a grid layout), saved and checked in the skin rule.
Since that moment the Sidebar width for the Left sidebar on Column Layout called "Two Column (Sidebar - Main)" is set to 3000 instead of 300. I have tried to change it several times but after check-in it is back to 3000. Even creating new column layouts does not help, they also have this setting at 3000 instead of 300 after check-in.
This definitely looks like a bug. Please fix.
Fyi, using Pega 7.2.1
***Updated by moderator: Lochan to add Category***
