How to keep main navigation expanded in Theme-Cosmos
By default, the main navigation in Theme-Cosmos is collapsed and only icons are visible. Navigation expands on mouse hover or when any of the elements inside the navigation is focused.
In some cases, there may be a reasonable need to keep the navigation expanded at all times. This can be achieved by adding additional CSS styling to the application.
Although, there is one thing to be aware of when using this solution: the expanded navigation will take up screen space, which means that the rest of the content will have less space to fit in.
Styling needed to keep main navigation expanded
In Theme-Cosmos portal can be displayed in two ways:
- With “Display application header” option enabled
- With “Display application header” option disabled
1. CSS styling needed for portal with the “Display application header” option enabled:
.screen-layout-header_left > .screen-layout-region-main-sidebar1 {
width: 22rem;
.flex.screen-layout-header_left > .screen-layout-region-main-middle {
padding-left: 22rem;
}The outcome of the styling:
2. CSS styling needed for portal with the “Display application header” option disabled:
width: 22rem;
.collapse-nav-auto > #sidebar-region-one .infinity-app-title,
.flex.content-item.main-header-search > span.primary_search > input::placeholder,
.flex.content-item.main-header-search > div > span.primary_search > input::placeholder {
opacity: 1;
.flex.content-item.main-header-search > span.primary_search > input,
.flex.content-item.main-header-search > div > span.primary_search > input {
width: 100%;
padding: 0 32px 0 46px;
font-size: 16px;
How to add proposed styling to the application
To add the proposed CSS styling to the application use “py-cosmos-custom-css” file. Simply override this file to your application and add custom CSS code there.
"py-cosmos-custom-css-file"
Overridden "py-cosmos-custom-css-file"
***Edited by Moderator Marije to add the Developer Knowledge Share tag***
