BMC Schweiz
CH
Last activity: 2 Mar 2022 6:02 EST
Dynamic Layout with non-proportional column width
I want to create a 3-column DynamicLayout format in the skin with lets say 50-25-25% column width (no ColumnLayout as they have fixed width columns). How can I define this in Pega 7.2.1?
Cheers,
Manuel
Hi Manuel,
Open Skin rule and serach for inline grid triple format under dynamic layout
Expand Column widths and set required width in % for columns.
OR create your own format using above steps.
Hope this helps !!!
Can't you use a nested Dynamic layout to acheive this requirement?
Like the first Dynamic layout will be of type "Inline Grid Double". So both of its column will have 50% of size.
Now on the 2nd column, include another "Inline Grid Double" Dynamic layout.
Using this design, you will get 3 columns during runtime, with 50%,25%, 25% in size.
Please let me know if it worked for your requirement!!
BMC Schweiz
CH
Hi Ajit,
thanks for the reply - the issue with embedded double layouts is that the breakpoint conditions dont work as desired as both have the same conditions to wrap.
But maybe with copies of "inline grid double" to "inner / outer 50-25-25" having the breakpoint conditions as desired - will check.
Cheers
Hi Manuel,
Hope this helps !!!
BMC Schweiz
CH
Thanks - thats what I searched for, seems that I missed the column width settings or it wasn available and fixed via hotfix in the meantime.
I will create a copy of "inline grid triple".
Blue Rose Technologies GmbH
BE
You can use inline grid triple format under dynamic layout and give column widths as per your requirement.
Thanks.
BMC Schweiz
CH
Thanks a lot for the reply - I got this info already.
