Trace a When rule
Is there a way to trace a WHEN rule? I am trying to see if a WHEN rule is firing and what the value is at run time?
Try using
@pxLogMessage("Successfully Ran When Rule",'f')=="true" as one of the Logic Conditions.
The above will write to the Log File if the condition/logic is true. Once your WHEN rule runs, you should be able to see the string 'Successfully Ran When Rule' in your log file.
You would need to trace the process that you expect to cause it to fire. In the Tracer settings, make sure When rules are selected.
Try using
