Is there a way to fetch cases of a specific case type into the Todo widget (Worklist)?
Hi all
I have a requirement to show only the cases of a particular case type in the Todo list of an operators. I have a case type called Application Submission, and only cases of ApplicationSubmission routed to the operator should be appearing in the Todo list (Worklist). Can we also show some case custom fields in the Todo widget along with the step name and the Case ID? I'm using Pega Infinity 24.2 Constellation.
Thank you
