Is there any way to conditionally/dynamically show flow action short description value.
I need to show two different flow action short description values for different conditions.
Is it possible to do?
Hi There,
Same sort of functionality is present in pyCaseActionArea section.
You can put another label with your own property holding the value based on condition.
By Default newAssignPage will have all the applicable FlowAction lebel present for use.
Ujjwal
