Greenfield Technology Aktiengesellschaft
HU
Last activity: 9 Jan 2025 11:22 EST
Table Show details - Expand all creates transaction ID error
We have a weird error with the following configuration:
There is a section with a table where in the Operations tab the Show details option is selected (see screenshot). The requirement is to have all rows expanded therefore the Expand all was checked.
However, in this situation if the case is closed (either closing the window or navigating back to the homepage), when the assignment is relaunched, the case is not opening. There are no errors in the tracer only in the logs "ERROR: posted transaction id 'xxx' for frame 'pyWorkPage' DOES NOT match record 'yyy'"
If the Expand all is unchecked everything works fine.
The flow action called in show details does not have any pre or post processing actions, no validations just the default settings.
For the time being we solved the expanding by setting the pyExpanded in a pre DT.
The question is if this is a known issue or are we doing something wrong?
PS.: Using Pega 24.1 with Theme Cosmos
