SystemPulse does not work on 717 (upgraded from 6.3)
Hi there,
My client was on PRPC 6.3 last year and moved to to 717. I noticed that two tables with triggers used to update pr_sys_updatescache.
Question - does the triggers still used for SystemPulse update?, I have seen a discussion somewhere that it is not used. if
1. dbo.pr4_rule has 3 triggers (trpr4_rule, trp4_rule_vw_del, trp4_vw_upd) - the triggers in dbo has no schema prefix - insert into pr_sys_updatescache
2. rules.pr4_rule also has the tree triggers (but the insert has schema "rules" prefix ie. insert into rules.pr_sys_updatescache
I think 717 upgrade back then also introduced split schema - I notice no new rules in dbo.pr4_rule_vw but most recent rules with pyCreateDatetime are in rules.pr4_rule_vw
1. I can see the dbo.pr_sys_updatescache table has the most recent rules...
2. the SystemPulse agent is running on both nodes
3. the Pulse Status also shows the same activities in the last 1 hour seen by botn nodes.
What should I check to see why the both nodes are not in synch?
Regards
Seri
