Stella
Last activity: 19 Sep 2019 2:27 EDT
Storing Attachments
We will have on average 5 attachments per case and each attachment to a case would be on average 10 meg in size. Currently we are storing attachments in the Pega database but I'm concerned whether this is a good idea or not. Perhaps we should be using a repository that Pega supports? What is the downside of using database to store the attachments? Gets expensive because the DB will grow large? Performance? What is Pega's recommendation for this?
I see there is an option in application rules to switch to a repository which I am not too familiar with but I assume it means storing attachments on a file server on the cloud since our app is running in the pega cloud. Can we easily switch to use repository and still get to our current attachments that were attached in the database? IS the switch from database to repository transparent? In other words do we have to change our application code besides the application rule(s)? We do have a feature in the application where we perform a word merge and attach cases and display the case via some common built in Pega activities. Should that still work?
Another thing to add is that we don't see much of a need for these attachments to be accessed outside of Pega only within case in Pega would the attachments be needed to be accessed.
