    AMEX
Last activity: 26 Jul 2017 1:34 EDT
Pega 7.1.8 Calling Stored Procedure
Hi Team,
I am calling a stored procedure (oracle) which accepts 1 input and returns 1 output.
I am using a Connect-SQL (browse) tab to call the stored procedure.
When I run the activity which calls RDB-List, it is returning the below error:
<pxRDBError>There was a problem performing a database query: There was a problem getting a list: code: 6550 SQLState: 65000 Message: ORA-06550: line 1, column 7: PLS-00201: identifier 'FIND_CCP' must be declared ORA-06550: line 1, column 7: PL/SQL: Statement ignored</pxRDBError><pxSQLStatementPre>\{ call find_ccp({mySQLPage.EmployeeID IN},{mySQLPage.pyUserIdentifier OUT})\}
I tried using RDB-Open. still the same issue.
Please help..
