Atomazing - BLOCKED! DO NOT Activate
KZ
Last activity: 2 Nov 2015 10:13 EST
Special symbols replace by ASCII code
Hi!
My problem is when I hover a pointer on a some Text Input, smart tip should be appeared, but it shows ASCII code of special symbols instead symbols.
Source of smart tip is Data Page.
Screenshots are attached.
How can I fix it?
Hi Sergey,
Please raise a support request on My Support Portal ( https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question) to get it further investigated by Pega Global Customer Support engineers.
Note: Mention the Mesh URL while raising the request.
Sonal Sharma
Hi Sergey - what version of PRPC are you using ?
Cheers
John
KZ
Hi John! We are using Pega 7.1.8
Hi Sergey,
The reported issue is fixed in Pega 7.1.10 release. While localizing any text using field value to a property that contains parentheses, '(' and ')' are getting encoded to ( and ) respectively.
In the fix, the double XSS filtering in pzGenerateLabelInclude RUF was removed
Sonal Sharma
KZ
Hi Sonal!
Can you please share some another way to fix it? Maybe some workaround? Our customer doesn't want to update to 7.1.10 release.
Hi Sergey,
Sonal Sharma
Hi Sergey Kiselev,
Were you able to open a SR per Sonal Sharma's above request? If so, please let us know so that we can add it to the thread for tracking.
Thanks in advance!
SR-A11117 has been raised
Thanks Rahul Sanghi! I've updated the thread with that information.
