Tech Mahindra
Last activity: 18 Jul 2017 10:16 EDT
SOAP Service - Dynamically Create Cases for Different Work Pools ( rulesets not available in Service AccessGroup)
I have SOAP Service which can not have authentication enabled due to Consumers are not ready to change.
Based on some attribute in the incoming SOAP Request, can i update current rulesets to create work objects for different work pools ?
I already have the required rulesets but how to update Current Rulesetlist before creating the case ? Any thoughts
***Updated by moderator: Lochan to close post***
Tech Mahindra
Found a way...! this should do it
ClipboardProperty ruleSetCp;
ruleSetCp = tools.findPage("TempAppPage").getProperty("pyRuleSetList");
int aAction = tools.getAuthorizationHandle().UPDATE_REPLACE;
try
final com.pega.pegarules.priv.authorization.PegaAuthorization authorization = (com.pega.pegarules.priv.authorization.PegaAuthorization)tools.getThread().getAuthorization();
boolean status = authorization.setRuleSets(tools, aAction, ruleSetCp);
oLog.infoForced("Rulesets update : " + status);
catch (PRSecurityException prsEx) {}
Please comment if there any other thoughts...!
Pegasystems
The agents currently do this by changing the accessgroup. You can refer to SYSTEM-QUEUE-SERVICELEVEL!ESTABLISHCONTEXT activity to see how the accessgroup is altered.
Tech Mahindra
I have been trying to use the following in my service activity with no luck
com.pega.pegarules.priv.authorization.PegaAuthorization auth = (com.pega.pegarules.priv.authorization.PegaAuthorization) tools.getAuthorizationHandle();
String strAccessGroup = auth.replaceAccessGroupToUse(tools, myStepPage.getString(".pyAccessGroup"));
The above code doesn't work for requestors of type App, only works for btach requstors.
String strAccessGroup = auth.setActiveAccessGroupToUse(tools, myStepPage.getString(".pyAccessGroup"));
i belive its not setting the provided accessgroup, because i see JAVA code executing properly
** Failed to find a 'RULE-OBJ-FLOW' with the name 'TESTFLOW' that applies to 'XXXXX-Work-Test'. There were 2 rules with this name in the rulebase, but none matched this request. The 2 rules named 'TESTFLOW' defined in the rulebase are: 1 related to applies-to class 'XXXXX-Work-Test', but were defined in rulesets which are not in your rulesetlist: 'SSG:01-01-01'. 1 unrelated to applies-to class 'XXXXX-Work-Test', for example: 'PegaPDFS-Work-testCasetype'. Current RulesetList:
{bunch of rulesets for the Service requestor }
1) Where is the Current RulesetList picked up from pxRequestor or pxThread
2) will we able to update that list run time ?
Any thoughts ? appreciate your help
Naveen
Tech Mahindra
try
Pegasystems
Regarding the code you posted, which I repeat below, how are you actually setting up your "TempAppPage" ? We tried to suggest your code to our customer, and they aren't clear on that question. Our customer is in a "JMS MDB Requestor session (container managed)" context. Thanks. /Eric
try
Tech Mahindra
Hello Eric,
Our requirement is something, We have many Rule-Applications deployed on same PEGA instance, we wanted to create a generic service to create / update cases for all the applications with out having their rulesets in servie accessgroup.
for that building a rulesetstack dynamically based on the input parameter
Here TempAppPage is just a page to hold ruleset stack which will be fed to below code to refresh the requestor ruleset stack
Instead of using the above code you call Code-Security.SetRulesets which will do the same thing.
Hope this helps
Cheers
Naveen
Naveen/Eric,
I have a similar requirement and I used the above snippet(for a JMS Service).. However it is still considering the static AG specified in the service package..Does the above snippet work well only for batch requestors?
Do we have a way to make it work for APP Requestor as well?
Tech Mahindra
I think for app requestors you can try the below.
auth.setActiveAccessGroup(tools.getThread(), AG);
let me know.
I tried it..However it didn't work.. I passed the 2nd parameter as a string(AG Name)..
Do we have access to the authorization package classes and methods? I looked at the engine APIs and I couldn't find this package in the help.
Tech Mahindra
don't think its available in the engine API. Check this activity
System-Queue-ServiceLevel.EstablishContext
Used the replaceAccessGroup method available in the above activity(System-Queue-ServiceLevel.EstablishContext) and got the below exception..
** Invalid requestor type APP; only BATCH requestors are supported by this method.
Can you provide screenshots for the ServicePage used by the soap service.
Please include all tabs
It may be that there is a conflict regards pooling and a context switch.
This is a JMS Service and the AG is initialized in the Service package data instance.
