Canadian Tire Corporation Ltd
Last activity: 27 Mar 2024 9:11 EDT
Smart Disputes: MasterCard Document Requirements when Reasserting a Chargeback (post Representment)
MasterCard Chargeback Manual outlines requirements for supporting document(see attachment) when reasserting a chargeback after Representment.
We are finding different actions within Smart Disputes when reasserting a chargeback depending on the original chargeback Condition Code under Reason Code 4853.
1) CC = 1 - Goods or Services were either Not as Described or Defective
- When a case was reasserted no EBDR form was generated (and no supporting documents were manually attached)
 - The case was ultimately rejected by MC due to no supporting documentation
2) CC = 2 - Goods and Services Not Provided
- When a case was reasserted an EBDR form was generated and attached by SD
Please clarify how SD is handling the different reassert case scenarios based on condition code and reason code. At a minimum, should an EBDR form be generated for all reassert scenarios?
***Edited by Moderator Marije to add Case INC-B4049 ***
***Edited by Moderator Marije to add correct Case INC-B1438 ***
