Select query for pr4_rule_library table is running more frequently
We are getting below alert many times in the logs. Not sure if it is common. We are seeing over 800 times on each node.
Alert: Database operation took more than the threshold of 500 ms: 653 ms SQL: select pzPVStream , pxCommitDateTime from PEGA_RULES.pr4_rule_library where "PYLIBRARYNAME" = ? and "PYRULESET" = ? and pxObjClass = ? order by "PYDECORATEDFUNCTIONNAME" , "PYRULESETVERSION" , pzInsKey
