Acxiom Corporation
Last activity: 14 Oct 2015 16:54 EDT
Extract of Rule-Utility-Library is slow and the entire system runs slow
We have recently had one of our instances change behavior. On startup, it hangs for about 10 minutes on the part where it is doing the extract of Rule-Utility-Library rules (about 30 seconds on other instances). Once it finally gets started, everything runs much slower than usual, including the IDE itself, and processing that we are trying to do. We are looking for any possible solutions or places to check for hints as to what might be going on.
Thanks for the hints. It turned out that it was because of the java option -Xrunhprof that we had turned on recently. I removed that and everything went back to normal.
