Segment Schedule Best Practice
In Production, we get the customer data feed once in a day and there is no real time feed and we run daily Batch campaigns. We are using Pega Marketing 8.3 version.
As per the Business Use Case, we have some child segments which is being called in multiple parent segments (used in daily campaigns). So, we expect the common child segment to get run once per day instead of getting refreshed by all the calling segments. And, we have other child segments which is being used in a single parent segment also.
To Implement this, will the below configuration be the recommended way?
- Refresh campaign Segment option will be enabled in the campaign Engagement to refresh the Parent segment
- Parent Segment (which calls both the common child segment and specific child segment)
- Enable Transactional Refresh - Unchecked
- Refreshable Segment - Checked
- Refresh Child Segments - Checked
- Common child segment (Being called in multiple segments)
- Refreshable Segment - Unchecked
- Refresh Child Segments - Unchecked
- Schedule it to run daily before all the daily campaigns run schedule (Can we rely on this Schedule completely to refresh the segments on daily basis?)
- Specific child segment (Being called in only one parent segment)
- No Schedule
