Sections not showing up in the portal
i have saved as an entire flow from work-quote class to work-ast class. All the rules associated with the flow have also been moved to the target class. There are no errors seen. However when i run the flow, the sections do not show up into the portal.
Did you save as the section rules into the new class as well?
