Cox Communications
Last activity: 25 Feb 2019 23:24 EST
Running Pega Robotics Runtime and Pega Personal Edition from the same machine
Is it possible to be running robotics runtime and pega persoanl edition from the same machine? I am running into some issues where my bot will register with the robot manager, but then if I make any changes to the pega system it loses connectivity. At that point, I have to delete my bot and restart it. I want to be able to test my bot by running a case, but when I run the case the bot gets disconnected. I was just curious if this is a limitation of running pega personal edition and runtime on the same machine, or if this is possible?
I am also running robotics studio and package server on the same machine, but I believe I don't even need to keep those running to run through my test scenario
