Capgemini
Last activity: 18 Jul 2022 3:10 EDT
Rule Set UI is distorted when opened
When ever we try to open a ruleset from the application or from any rule form the UI is distorted.
JPMorgan Chase
Rule cache could have been corrupted. Clear all cache tables and restart your application.
Capgemini
@SriHarsha Anika
Hi Harsha thank you for your response
truncate table pr_sys_appcache_dep
truncate table pr_sys_appcache_entry
truncate table pr_sys_appcache_shortcut
truncate table pr_sys_cache_dep
truncate table pr_sys_cache_entry
truncate table pr_sys_cache_impl
truncate table pr_assembledclasses
truncate table pr4_rule_sysgen
truncate table pr_sys_rule_impl
truncate table pr_sys_updatescache
are these above tables enough for truncating them?
Regards
Naresh Kommuri
JPMorgan Chase
Hello yes these tables should do the needful , apart from the above tables . clear the temp directory on your server and also remove the mark up file . This ensures all the cache at various level's is synched right in fresh mode during next start.
Also check if the hazel cast is running correct with out any errors. ( check your logs for any hazel cast errors if any). if any observed then make sure it is addressed. so that cache is not corrupted frequently.
Capgemini
@SriHarsha Anika
Hi Harsha,
The application has dependency on the temp files pin the server, if we remove them the application won't come up.
Sure will keep a tab on the hazel cast
Regards
Naresh Kommuri
JPMorgan Chase
@NareshKommuri Remove the mark file alone at-least . that should force rebuild all cache on box.
Capgemini
Capgemini
@SriHarsha Anika
Hi Harsha,
I have truncated the cache tables and now the rule set UI is coming up as expected.
Thank you!
Regards
Naresh Kommuri
JPMorgan Chase
@NareshKommuri Could you please mark the solution as accepted and close this thread.
IQZ Systems
@NareshKommuri Another cause could be application skin overriding style formats of default skin which are used in this rule form.
To confirm, change your application skin, to default skin . log out & login. Then open the ruleset
