Rule is not referring the highest version that I deployed, why?
I have deployed a ruleset with 10 rules, those 10 rules are sections, all of them are in same version, after deployment when I am doing unit testing I see that one section is not referring the highest version that I deployed.
Application is pointed to the correct ruleset, 9 sections are working fine and there is an issue with one section.
With respect to Rule availability all 10 rules are available, it is in correct context, all checked in rules and took a JAR and deployed.
I have same access in Dev and QA, that one section is still referring to the old version.
How will you start debugging, what is your thought process?
