The Rule Instances are not visible whereas if we open the rules from Ruleset Version its visible in that case,why?
Have moved a Ruleset Version ABCInt:01-01-01 from dev to other environment by creating a product rule, now if I open the ruleset from Records>Sysadmin>Rulesets>ABCInt then i am able to see all the integration rules present in it but if try to search for that particular rule its not visible. Even if i go and search that Connect Rule under Connect-Rest no results are found.One small observation i noticed is that in Dev the product that i created the app context was automatically taken as:ABCFWIntegration:01.01.50 but to the other environment where i have moved this rule this application version is only present till ABCFWIntegration:01.01.40.So Is that the reason?why the rules are not present properly?
Attaching SS for reference
