ME Bank
Last activity: 2 Jul 2018 8:41 EDT
Revalidate and save not occuring after deploying rulesets
We deploy packages through the prpcUtils command line tool. It has been reported however that even though the rulesets are successfully deployed, Revalidate and Save tasks do not happen
My understanding is that this step was performed post import and only when required. If rulesets are deployed manually via the UI, "Revalidate and Save" tasks are performed via the utility available and also as a UI.
Would sincerely appreciate if someone could advise of any detail that needs to be defined in the prprcProperties file for revalidate and save to occur after every deployment or if a specific Class needs to be indicated in the properties file enabling validation only for that class.
Pega version currently in use is 7.1.9.
Thanks and would highly appreciate any advice
