EPAM Systems
Last activity: 3 Jul 2019 3:45 EDT
Report definition- Drill down option is not working
Hi Team,
We have a configured a report definition with drill down option in Pega 8.2 . After running and clicking, drill down report is not working.
I have tried the same on ootb Report with drill down option and that is also not working.
Please advise.
Lalit
HCL Technologies
Thanks for response. So, the OOTB report which we ca use for this example is pxGuardrailSummaryByAppSchedule. And when we are running it, we are not able to drill down further to view details. In browser console also I am seeing some errors, below you can find snippet of it. Please let me know if you need more info.
Error in the launched portal Uncaught TypeError: a is not a function at line 597 Column 166 file https://uapg2ad10.devfg.rbc.com:9572/secureapp/sip08/prweb/PRServlet/Fy7qvZgNMHTyvpO5QpamzWhMmopMdKsR*/webwb/pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js
pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js:597 Uncaught TypeError: a is not a function
at pega.ui.Doc.harness_execute (pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js:597)
at pega.ui.Doc.initializeInner (pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js:575)
at pega.ui.Doc.initialize (pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js:530)
at r (pzpega_ui_harnesscontext_1639437542!pzevalharnessjson_11274272984.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1192545302!pega_yui_13027834416!desktopwrapper_13441957966!developerwrapperapi_12187829019.js!pzsyncappexplorer_13993928924.js!pzautomationscripts_1782369863!pzpega_ui_jquery_11946158806!pega_ui_harness_1596074768!pzpega_ui_harness_actions_12323798486!pzpega_ui_crc32_1193200667!pzpega_ui_messaging_1847971439!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_12606050251!!.js:46)
pzaftinfra_11759658373.js!!.js:1 Error in the launched portal Uncaught ReferenceError: callDrillDownReport is not defined at line 2372 Column 59579 file https://uapg2ad10.devfg.rbc.com:9572/secureapp/sip08/prweb/PRServlet/Fy7qvZgNMHTyvpO5QpamzWhMmopMdKsR*/!TABTHREAD1?pyActivity=Rule-Obj-Report-Definition.WBRun&InsHandle=RULE-OBJ-REPORT-DEFINITION%20DATA-RULE-SUMMARY%20PXGUARDRAILSUMMARYBYAPPSCHEDULE%20%2320190401T095216.185%20GMT&portalThreadName=STANDARD&portalName=Developer&target=popup&pzHarnessID=HID7C1333F38CC9D3A35239A93C6A141D47
!TABTHREAD1?pyActivity=Rule-Obj-Report-Definition.WBRun&InsHandle=RULE-OBJ-REPORT-DEFINITION DATA-RULE-SUMMARY PXGUARDRAILSUMMARYBYAPPSCHEDULE %2320190401T095216.185 GMT&portalThreadName=STANDARD&portalName=Developer&target=popup&pzHarnessID=HID7C1333F38CC9D3A35239A93C6A141D47:2372 Uncaught ReferenceError: callDrillDownReport is not defined
at HTMLTableCellElement.onclick (!TABTHREAD1?pyActivity=Rule-Obj-Report-Definition.WBRun&InsHandle=RULE-OBJ-REPORT-DEFINITION DATA-RULE-SUMMARY PXGUARDRAILSUMMARYBYAPPSCHEDULE %2320190401T095216.185 GMT&portalThreadName=STANDARD&portalName=Developer&target=popup&pzHarnessID=HID7C1333F38CC9D3A35239A93C6A141D47:2372)
Hemant
Which OOTB report? Does it also fail as [email protected]?
If you hit F12 and check the console, are there any error messages?
When running a network trace, do you see any requests being sent out and/or error codes coming back?
