Last activity: 23 Nov 2016 0:23 EST
Repeat grid inline edit, on using click row to edit option row goes back to read only mode when clicked out of the grid.
Hi Team,
I have configured a layout as a repeat grid and I have set the row operation as inline mode and selected click row to edit radio button , So with this configuration on click of a row it will be editable but when users clicks else where the row is no longer editable , it goes back to read only mode.
Is there a way that the row remains editable even when users click out of the row?? I am using Pega version 7.2
Please help.
Thanks & Regards,
Saba
Northbridge
HI Saba,
Use "Always Editable" option
Updated: 26 Sep 2016 2:33 EDT
Hi ,
Thanks for your quick reply, but as per requirement we dont want row to be always editable, row should become editable only when user clicks on it.
Saba
Credera
It's the default behaviour of Pega, if you want rows always in editable mode, choose Rows always editable option
Hi Dharanitharan,
Saba
Blue Rose Technologies GmbH
DE
The row should become editable when user clicks on it and at what point do you expect the row to go back to readonly ?
Hi ,
We have a save button on click of save button the row data should save in DB and can become read only, but here as soon as i click out of the row or grid its becoming read only.
I know its the OOTB behaviour, but wanted to know is there way that we can achieve the same.
Saba
Hello Saba,
This is the expected behavior when using "Click row to edit". As the term states, the row will be editable only when the focus is on it. Clicking anywhere outside it will lose focus.
As Dharanitharan stated, you need to use the Always Editable setting for the sae.
Best Regards,
Mounika
Navy Federal Credit Union
We had simillar kind of requierment where user should see maximum of one row ediatble at a time and clicking outside of the grid should not become read-only, to my knowledge we dont have ootb feature for this. we did it as below
on row click refresh the section and invoke a data transform passing current index as parameter and set a flag which is used to make all fields editable and unset for all other list items.
Each row has save button corresponding to it to save the changes. on click of save reset the flag back again.
Yhanks
Sai Phaneendra Yakkali
Nipun Reddy Thirumala Reddy
Incessant Technologies
Add action in actions tab like OnClick or doubleclick edit the item, which may helps your requirement.
Team,
Any thoughts on the above question other than making row always editable....
I know its OOTB behaviour that the grid goes read only when its loses focus but wanted to know if there is any custom script that could be used to accomplish the above said requirement.
Thanks in advance
T-Systems
Hi Saba,
How did you achieve this functionlaity, I have the same requirement where i need to edit the row, if user clicks on edit button.
