Remote Host login for Mean Operation
We are calling mbean operation from an activity to get listener status. Issue is, we are getting only status of listner from the node in which activity is running from. We need to get listner status from other nodes too. For this we may need to remote login to other nodes. The code which Kevin shared in related topic (https://mesh.pega.com/docs/DOC-81928) seems to have remote login for JBoss server. Appreciate if someone can provide a sample code to do remote login to a different node in websphere server.
Code used:
String host = "pgwasshrxx";
int port = 9999;
String urlString ="service:jmx:remoting-jmx://" + host + ":" + port;
javax.management.remote.JMXServiceURL serviceURL = new javax.management.remote.JMXServiceURL(urlString);
java.util.Map map = new java.util.HashMap();
String[] credentials = new String[] {"[email protected]", "rules"};
map.put("jmx.remote.credentials", credentials);
javax.management.remote.JMXConnector jmxConnector = javax.management.remote.JMXConnectorFactory.connect(serviceURL, map);
javax.management.MBeanServerConnection connection = jmxConnector.getMBeanServerConnection();
Log:
Code used:
int port = 9999;
Log:
2016-09-15 00:08:58,255 [ WebContainer : 0] [ STANDARD] [ ] [ CDR:01.03.01] (eFirst_FW_Renewals_Work.Action) INFO pgwasshr3|sv-xapp-p022.carefirst.com xxxxx - java.net.MalformedURLException: Unsupported protocol: remoting-jmx
2016-09-15 00:18:28,592 [ WebContainer : 21] [ STANDARD] [ ] [ CDR:01.03.01] (eFirst_FW_Renewals_Work.Action) INFO pgwasshr3|sv-xapp-p022.carefirst.com xxxxx- java.net.MalformedURLException: Unsupported protocol: remoting-jmx
2016-09-15 00:24:54,239 [ WebContainer : 32] [ STANDARD] [ ] [ CDR:01.03.01] (eFirst_FW_Renewals_Work.Action) INFO pgwasshr3|sv-xapp-p022.carefirst.com xxxxx - java.net.MalformedURLException: Unsupported protocol: remoting-jmx
