Invoke api to populate "Search Index host node setting"
Hi Community,
I was able to Change DSS setting by activity API call. example :
Select activity “pxSetDynamicSystemSetting” Select Action and RUN.
I was looking for a similar out of the box activity to set "Search Index host node setting" for 'Host nod ID' and 'File directory' (Designer Studio --> System --> Settings --> Search).
Background
I have a multi node environment and I have assigned one of the nodes as a search node, I need to get the node id for this search node and use it to update the "Search Index host node setting" 'Host nod ID' field. hope the requirement is clear.
