Release Lock after certain period of time
Is there a way to release the lock after a certain period of time?
Ghina
***Updated by Moderator: Marissa to update topic categories***
Ghina
You can specify a default lock time on the case type in Pega 7.
You can go through the below link for more info on locking
https://pdn.pega.com/about-pega-7-case-locking
Thank you,
Srijith.
1. Go to Case Explorer and select the case where you want to set locking mechanism.
2. Go to Settings tab -> Locking.
Locking mechanism can be handled in below ways:
1. Records--->Sysadmin-->System
Enter the maximum time in minutes that an instance — for example, a work item — remains locked when opened. The default value is 30 minutes.
2. As mentioned above by other members,
2. Go to Settings tab -> Locking. This is not working from my side after 30 mins the lock was not released from pr_sys_locks
