Cognizant
Last activity: 25 Jun 2024 2:14 EDT
In a RD without using filter how can we extract records with only a particular name.
I want my report definition to fetch a particular record with Name="Nutan",but without using filters. Is this possible?
Reply
Updated: 25 Jun 2024 2:14 EDT
This can be achieved by ABAC - Read , Configure Access control policy condition and when rule with the required filter or condition , then run the report of that particular class , It will be filtered with the condition mentioned in Access control policy , But there will be no filter in the RD.
But for just filtering ABAC is not really required.
Please go through the course on ABAC- https://academy.pega.com/topic/attribute-based-access-control-abac-security-model/v1
Infosys Limited
It could be possible in the other way by using the sql functions. Refer emded function rule.
Cognizant
@P.Siva.Praveen Could you elaborate please?or if possible add a screenshot for the same.
Cognizant
@P.Siva.Praveen could you please share screenshot if possible?
Maantic Inc
Why are you using report definition when you do not want to use filters?
Maantic Inc
Even if you use a function alias or a subreport, it'll still be using filters. To my knowledge I've not seen being used, its not practical.
