Cognizant
Last activity: 2 Aug 2018 7:45 EDT
Radio Button Control Format is not working in Grid layout
Hi Team,
I have an issue where Radio button control format is working normally(Showing the proper colour) in dynamic layout but it is not working when I use it in Grid Layout(I am using pyselected property for the radiobutton).
The source for Grid layout is Datapage which has data transform as its source. Depending on the conditions, I am setting pyselected property to either true or false.
I am not facing any issue with the checkbox but as per the requirement, we need to use Radiobutton.
Please find the attached screenshots and help me to resolve the issue.
Thanks in Advance!
Divyateja
Aaseya IT services Pvt. Ltd.
SA
Hi DivyaTeja,
Please use control "pzGridRadioButton" when you use it in Grid repeating layout.Attached screenshot for the reference.
Cognizant
Hi Swathi,
Thank you for the reply. I have tried to modify it to pzGridRadioButton but it is still the same issue.
I observed that there is no control format in Presentation tab upon changing this way.
Merkle
Could you please try with DisplayYesNo control?
Gopesh
Cognizant
I tried with DisplayYesNo control but it's still the same. Please find the attached.
Updated: 2 Aug 2018 3:40 EDT
Merkle
Thanks for trying and sorry the solution didn't work.
Have you tried with customize control? You can reuse DisplayYesNo control's HTML and can customize as per your requirement. I think that would be easy.
Gopesh
Can you try in the same in UI Gallery also? Please let us know the version of PRPC/Framework also.
Cognizant
Could you please elaborate on the above process to try in UI Gallery?
We are using 7.3 Version of PRPC and Customer Service is the Framework.
Divyateja, rather than placing the radio buttons directly in the grid can you use a wrapper section defined on the grid class to contain the radio buttons, and embed the section in the grid cell. This should stop the automatic grid formatting that gets applied to the radio button.
Sriram Kota
Further to the above suggestion here is an example. I think that the single radio button format when configuring a true / false type property in the grid is expected to easily support the requirement to use a single radio button per grid row to select a single row.
Run time example of same radio button control configured directly in the grid, and in a wrapper section:
Wrapper section configuration:
Cognizant
Thanks much for the reply. I have tried the above solution but it is still the same issue. Radio button is not coming in colour.
