Scotiabank
Query regarding OOTB PartyApprovalMajority
Hi All
Say I have requirement for a majority approval voting and will be using OOTB PartyApprovalMajority flow, now if I use the it, assignments for voting will be created for all workparty defined in the Case. But say I have 5 workparty defined in the Case and I want only 3 parties to participate in the approval voting, is this possible by using the OOTB flow?
Sandeep
Hi
This flow rule is available. So you can edit it anytime as per your application requirement.
Now coming to your specific requirement. Well , i can see that the Approval assignment shape has the routing info "ToWorkParty" which routes it to all parties involved.
If you dont want that to happen then you can use your own routing logic by saving as ToWorkParty with a new name and modify the step 1 where we are hardcoding it by this ".pyWorkParty(param.Party).pyWorkPartyUri
