pyResourcePath does not substitute actual values from Params after upgrading to 8.7.3 from 7.3.1
Greetings. Hope you are all well! We recenlty upgraded from Pega 7.3.1 to Pega 8.7.3 and all our connect rules are using references like {endpoint}/{referenceValue} within Resource Path of a connect rule and substituted via Map from Clipboard
endpoint = DataPage.endpoint(TEST)
referenceValue = Param.referenceValue
We were using this ResourcePath in a data table to record the Connect calls for debugging and performance. In Pega 7.3.1, I can see the values are substituted as https://url/1234566 however in Pega 8.7.3, I see this as {endpoint}/{referenceValue}. We cannot upgrade to new endpoint configuration now as this is a 6 year old application and changing this will have implications to business. Can someone please let me know if there is any other way to get the actual ResourcePath?
Bharat
