pxDateTime based date picker doesn't appear when filtering reports
I want to create a new report in Pega Marketing based on 7.2.1. When I drop onto the "Filtered by" area Date columns, which use deprecated UI controls the Date picker works as expected. However when I want to add a Date column with associated pxDateTime I only see an empty placeholder. Both cases point to the same pzCalendar final rule from the Pega-Reporting:07-10-09 class.
I have attached a screenshot. Either pxDateTime hasn't been thoroughly tested or I am missing something.
