Quest Diagnostics
Last activity: 27 Sep 2019 22:18 EDT
Properties Configured in RDA is passing as NULL even though it is properly set in PEGA side
In our case, On performing an Action in PEGA, the bot triggers. For that, few properties are passed as input to the Automation. Those properties has value in pega side while submitting(Confirmed in Tracer).But when checked in Automation data port,the value is passing as NULL.
Note:The properties are configured properly from automation side and Working as expected in lower Environment.
Can you clarify what you mean by "lower" environment.
