Project unloaded from solution
Hello all,
During developing I encounter a problem when adding a new project.
I have a bigger solution and I want to add a new project. It's an project with existing adapter and automations.
When I add this project and set the references nothing seems wrong. However when the solution is closed and I start the solution again, the project is unloaded and I get the message that the Guid Format is not recognized. This keeps reoccuring.
I added some screenshots.
the project is still existing in my files, however all the folders are empty
Does anyone know what I should do?
Thank you!
Marlot
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
