Anthem
Posted: November 28, 2017
Last activity: December 21, 2017
Last activity: 21 Dec 2017 10:28 EST
Production environment Database connection failure.
Hi Team,
Please find the Production environment Database connection failure error below.
2017-11-06 18:32:46,208 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ PegaRULES:07.10] (ion.context.GlobalContextCache) ERROR - Error in counting records in the pr_sys_app_hierarchy_flat table for appHash=PegaRULES!en_US__shared!PRPC:Agents!07.10$20e212aa01214ead2b194eb1f2a19e66
com.pega.pegarules.pub.database.ConnectionException: Database-General Problem encountered when getting connection for database pegarules 0 08S01 The connection to the host DBP_CTRAN2, named instance ctran2p failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.
Caused by SQL Problems.
Problem #1, SQLState 08S01, Error code 0: com.microsoft.sqlserver.jdbc.SQLServerException: The connection to the host DBP_CTRAN2, named instance ctran2p failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434.
Show More
Hi Team,
Problem #1, SQLState 08S01, Error code 0: com.microsoft.sqlserver.jdbc.SQLServerException: The connection to the host DBP_CTRAN2, named instance ctran2p failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.
Please suggest.
Show Less
