TCS
Last activity: 22 Feb 2018 14:35 EST
Problem while starting Pega PRPC 7.2 personal edition, Please find below are the error logs.
C:\PRPCPersonalEdition\tomcat\webapps\prweb\WEB-INF\lib\boot\prbootphase2.jar (The system cannot find the path specified)
Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
java.sql.SQLException: Cannot create PoolableConnectionFactory (FATAL: the database system is starting up)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2293)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2038)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1532)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.printConfiguration(PRBootstrap.java:772)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:665)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4738)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5181)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:945)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1798)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.postgresql.util.PSQLException: FATAL: the database system is starting up
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:427)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:203)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:65)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:159)
at org.postgresql.Driver.makeConnection(Driver.java:415)
at org.postgresql.Driver.connect(Driver.java:283)
at org.apache.tomcat.dbcp.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:255)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2303)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2289)
... 21 more
22-Feb-2018 13:19:43.854 19830421 [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap.
============ PegaRULES Bootstrap Configuration ============
Date: Thu Feb 22 13:19:43 IST 2018
Java Version: Oracle Corporation 1.8.0_66
Configuration: file:/C:/PRPCPersonalEdition/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode:
(!) Unable to use given database configuration
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
22-Feb-2018 13:19:43.854 SEVERE [localhost-startStop-1] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:720)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:662)
22-Feb-2018 13:19:43.854 SEVERE [localhost-startStop-1] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:208)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:324)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:304)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:409)
Hi Sanjay,
Thanks for posting on PSC.
As per logs shared, "PoolableConnectionFactory" SQLException is occurring and this happens only when you have a network issue, please verify your database communication link. Make sure that your application has network access to your database environment(It may be restricted by any firewall and blocking connection ports ).
Also, I have found similar stack trace reported earlier and probable root cause:-
Maybe there is no service listening on the port you are trying to connect to. Following things could be happening
- The server is not started.
- You are trying to connect to the wrong port number.
Please try using a different port in server.xml and restarting your Tomcat.
Hope it addresses issue on your end. Kindly notify if it does by marking this post as answered.
Asif
