Problem with problem flow
After completing request the case should be removed from the work queue but here that is not happening .There are two path-
1. when process goes through a normal process then it will stuck in the work queue.
2. Another observation is process goes 1st to flow problem and later complete then it will not stuck
can anyone help me ?
